CAN FD 5 Click
PID: MIKROE-4286
CAN FD 5 Click is a compact add-on board that contains a high-speed CAN transceiver that
supports both CAN and CAN FD protocol types. This board features the UJA1162A, a ‘selfsupplied’ high-speed CAN transceiver integrating an ISO 11898-2:2016 and SAE J2284-1 to SAE
J2284-5 compliant CAN transceiver with Sleep Mode from NXP Semiconductors. It supports
many additional features like an under-voltage detection, mode control via a single GPIO pin,
remote and local wake-up capability, overtemperature shutdown, and a very low quiescent
current in Sleep mode. This Click board™ is suitable for HS CAN networks in automotive
applications and networks in industrial applications, in electric power steering (EPS), HVAC
climate control, tire pressure monitoring system (TPMS), and many more.
CAN FD 5 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
CAN,CAN FD
Applications
Can be used for a HS CAN networks in
automotive applications and networks in
steering (EPS), HVAC climate control, tire
more.
On-board modules
CAN FD 5 Click is based on the UJA1162A, a
‘self-supplied’ high-speed (HS) CAN
and SAE J2284-1 to SAE J2284-5 compliant
Semiconductors.
Key Features
Under-voltage detection, remote and local
shutdown, and a very low quiescent current in
Sleep mode, and more.
Interface
UART
ClickID
No
Compatibility
mikroBUS™
Click board size
L (57.15 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
CAN FD 5 click schematic
UJA1162A datasheet
TLS850B0TBV33 datasheet
CAN FD 5 click 2D and 3D files
CAN FD 5 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4286”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+199.64367
- 5+195.65517
