MIKROE-4287
MIKROE-4287
    MIKRO
    TPS61391 脉宽调制器(PWM) 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4287 数据手册
Boost 3 Click PID: MIKROE-4287 Boost 3 Click is a compact add-on board that contains a boost converter with an integrated current mirror function. This board features the TPS61391, a 700-kHz pulse-width modulating (PWM) Step-Up converter with a 70V switch FET with an input voltage up to 5.5V from Texas Instruments. The TPS61391 includes an accurate current mirror, with two selectable gain options (1:5 or 4:5), and provides high optical-power protection with an additional FET in series with the APD power path, with the typical response time of 0.5µs. This Click board™ is designed to be used for applications such as biasing and monitoring the avalanche photodiodes (APD) in the optical receivers, but it also can be used as a high voltage sensor supply or in battery-powered and automotive applications. Boost 3 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Boost Applications Can be used for applications such as biasing and monitoring the avalanche photodiodes (APD) in the optical receivers, but it also can be used as a high voltage sensor supply or in battery-powered and automotive applications. On-board modules Boost 3 Click is based on the TPS61391, a 700-kHz pulse-width modulating (PWM) StepUp converter with a 70V switch FET with an input voltage up to 5.5 V from Texas Instruments. Key Features An under-voltage lockout, high optical power protection, wide output voltage range from 20V to 70V, current mirror function, and more. Interface GPIO ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads Boost 3 click 2D and 3D files TPS61391 datasheet Boost 3 click example on Libstock Boost 3 click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4287 价格&库存
很抱歉,暂时无法提供与“MIKROE-4287”相匹配的价格&库存,您可以联系我们找货
MIKROE-4287
  • 1+217.647911+28.28390
库存:1
