MIKROE-4290
MIKROE-4290
    MIKRO
    SCD41,SPS30 空气质量,二氧化碳(CO2) 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4290 数据手册
HVAC Click PID: MIKROE-4290 HVAC Click is a compact add-on board that contains Sensirion’s next-generation miniature CO2 sensor. This board features the SCD41, a carbon dioxide sensor build on the photoacoustic sensing principle, and Sensirion’s patented PASens® and CMOSens® technology to offer high accuracy at a minor form factor. On-chip signal compensation is realized with the build-in humidity and temperature sensor. It operates within a specified range from 400 to 5’000 ppm, configurable through the I2C interface with a single shot mode supported. This Click board™ is also suitable for indoor air quality applications using an additional SPS30 that allows smart ventilation systems to regulate ventilation in the most energy-efficient and human-friendly way, maintaining low CO2 concentration for a healthy, productive environment. HVAC Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Environmental,Gas Applications Can be used for indoor air quality applications and in smart ventilation systems to regulate ventilation in the most energy-efficient and human-friendly way, maintaining low CO2 concentration for a healthy, productive environment On-board modules SCD41 - Sensirion’s next-generation miniature CO2 sensor Key Features Low power consumption, high accuracy, photoacoustic sensor technology PASens®, integrated temperature, and humidity sensor, additional connection to SPS30 particulate matter sensor, and more. Interface I2C,UART ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads HVAC click 2D and 3D files SCD41 datasheet SPS30 datasheet HVAC click schematic HVAC click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4290 价格&库存
很抱歉,暂时无法提供与“MIKROE-4290”相匹配的价格&库存,您可以联系我们找货
MIKROE-4290
    • 1+662.65328
    • 5+649.40688
    库存:2
    MIKROE-4290
    • 1+708.512201+90.23820
    库存:4
