MIKROE-4289
MIKROE-4289
    MIKRO
    PCA9538A,VNHD7008AY 电机驱动器 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4289 数据手册
H-Bridge 6 Click PID: MIKROE-4289 H-Bridge 6 Click is a compact add-on board that contains a DC motor driver for automotive applications. This board features the VNHD7008AY, an H-bridge motor driver for automotive DC motor driving from STMicroelectronics. The VNHD7008AY, an I2C configurable motor driver, features an undervoltage shutdown, load current limitation, overload active power limitation, overtemperature shutdown, and more. This Click board™ also contains the PCA9538A, a lowvoltage 8-bit GPIO expander for communication between MCU and motor driver. H-Bridge 6 Click is suitable for automotive motor control applications like automotive brushed DC motor, or in applications such as body control module (BCM), car-seat control, and others. H-Bridge 6 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Brushed Applications Can be used for automotive motor control applications like automotive brushed DC motor, or in applications such as body control module (BCM), car-seat control, and others. On-board modules H-Bridge 6 Click is based on the VNHD7008AY, a DC motor driver for automotive applications that integrates a full protected dual high-side driver and protection for the external power MOSFETs from STMicroelectronics. Key Features Fully protected HSD with MultiSense feedback, undervoltage shutdown, overvoltage clamp, load current limitation, overload active power limitation, overtemperature shutdown, cross current protection, and more. Interface I2C,PWM ClickID No Compatibility mikroBUS™ Click board size L (57.15 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads H-Bridge 6 click 2D and 3D files VNHD7008AY datasheet PCA9538A datasheet H-Bridge 6 click example on Libstock H-Bridge 6 click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4289 价格&库存
很抱歉,暂时无法提供与“MIKROE-4289”相匹配的价格&库存,您可以联系我们找货
MIKROE-4289
  • 1+398.361561+51.53870
