MIKROE-4293
MIKROE-4293
    MIKRO
    ANV32AA1 SRAM 存储器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4293 数据手册
SRAM 3 Click PID: MIKROE-4293 SRAM 3 Click is a compact add-on board that contains a serial non-volatile SRAM with a high storage capacity. This board features the ANV32AA1WDK66, a 1Mb serial SRAM with a nonvolatile SONOS storage element included with each memory cell organized as 128k words of 8 bits each from Anvo-System Dresden. The serial SRAM provides fast access & cycle times, high data accuracy, ease of use, and unlimited read & write accessed by a high-speed SPI compatible bus. This Click board™ is suitable to store drive profiles, configurations, and similar data, or for applications such as medical devices, industrial automation (for example, motor control and robotics), smart metering systems, and many others. SRAM 3 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type SRAM Applications Can be used to store drive profiles, configurations, and similar data, or for applications such as medical devices, industrial automation (for example, motor control and robotics), smart metering systems, and many others. On-board modules SRAM 3 Click is based on the ANV32AA1WDK66, a serial non-volatile SRAM with double memory architecture and SPI serial interface organized as 128k words of 8 bits each from Anvo-System Dresden. Key Features Low power consumption, high storage capacity, fast access & cycle times, high data accuracy, ease of use, and unlimited read & write accessed by a high-speed SPI compatible bus, and more. Interface SPI ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads SRAM 3 click 2D and 3D files ANV32AA1WDK66 datasheet SRAM 3 click example on Libstock SRAM 3 click schematic TXB0108 datasheet Powered by TCPDF (www.tcpdf.org)
MIKROE-4293 价格&库存
很抱歉,暂时无法提供与“MIKROE-4293”相匹配的价格&库存,您可以联系我们找货
