MIKROE-4294
MIKROE-4294
    MIKRO
    KP229E2701 压力 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4294 数据手册
Pressure 13 Click PID: MIKROE-4294 Pressure 13 Click is a compact add-on board that contains an integrated pressure sensor for manifold air pressure measurement applications. This board features the KP229E2701, a miniaturized analog manifold air pressure sensor based on a capacitive principle from Infineon. This sensor converts the pressure of 10 kPa to 300 kPa into an analog output signal, a voltage range of 0.40 V to 4.65 V. Also, the manifold pressure data can be used to compute diagnostics of leakages and malfunctions of the exhaust gas recirculation valve. The high accuracy and the high sensitivity of the KP229E2701 make this Click board™ a perfect choice for advanced automotive applications as well as in industrial and consumer applications. Pressure 13 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Pressure Applications Can be used for advanced automotive applications as well as in industrial and consumer applications. On-board modules Pressure 13 Click is based on the KP229E2701, a miniaturized analog absolute pressure sensor based on a capacitive principle from Infineon. Key Features Low power consumption, high precision pressure sensing (± 2.5 kPa), ratiometric analog output, large temperature range, automotive qualified, and more. Interface Analog ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads Pressure 13 click 2D and 3D files KP229E2701 datasheet Pressure 13 click example on Libstock Pressure 13 click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4294 价格&库存
很抱歉,暂时无法提供与“MIKROE-4294”相匹配的价格&库存,您可以联系我们找货
