MIKROE-4332
MIKROE-4332
    MIKRO
    DAC80501 数模转换器(DAC) 数据采集 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4332 数据手册
DAC 9 Click PID: MIKROE-4332 DAC 9 Click is a compact add-on board that contains a fully-featured, highly accurate digital-toanalog converter. This board features the DAC80501, a 16-bit voltage-output digital-to-analog converter with precision internal reference from Texas Instruments. It supports both I2C and SPI serial interface and offers a linearity of < 1 LSB. It also includes a 2.5V internal reference, giving full-scale output voltage ranges of 1.25V, 2.5V, or 5V, incorporate a Power-On Reset function, consume a low current of 1mA, and include a Power-Down feature that reduces current consumption to typically 15μA at 5V. This Click board™ is suitable for applications such as offset and gain control, VCO tuning, programmable reference, and more. DAC 9 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type DAC Applications Can be used for applications such as offset and gain control, VCO tuning, programmable reference, and more. On-board modules DAC 9 Click is based on the DAC80501, a 16-bit voltage-output digital-to-analog converter with precision internal reference from Texas Instruments. Key Features Low power consumption, low glitch energy, buffered output voltage range, internal/external voltage reference, selectable serial interface, high accuracy, and more. Interface I2C,SPI ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads DAC 9 click 2D and 3D files DAC80501 datasheet DAC 9 click schematic DAC 9 click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4332 价格&库存
很抱歉,暂时无法提供与“MIKROE-4332”相匹配的价格&库存,您可以联系我们找货
MIKROE-4332
    • 1+138.39990
    • 5+135.62982
    库存:29
