MIKROE-4346
MIKROE-4346
    MIKRO
    AD9834 波形发生器 时钟定时 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4346 数据手册
Waveform 2 Click PID: MIKROE-4346 Waveform 2 Click is a compact add-on board that contains a direct digital synthesis device for waveform generator applications. This board features the AD9834, a 75 MHz low power DDS device capable of producing high-performance sine/triangle/square outputs from Analog Devices. It provides the capability for phase and frequency modulation and has an on-board comparator that allows the production of a square wave signal for clock generation. With a 75 MHz clock rate resolution of 0.28Hz can be achieved, while similarly, with a 1 MHz clock rate an AD9834 can be tuned to 0.004Hz resolution. This Click board™ represents an ideal candidate for power-sensitive applications, frequency stimulus/waveform generation, frequency phase tuning and modulation, and many more. Waveform 2 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Clock generator Applications Can be used for power-sensitive applications, frequency stimulus/waveform generation, frequency phase tuning and modulation, and many more. On-board modules Waveform 2 Click is based on the AD9834, a 75 MHz low power DDS device capable of producing high-performance sine/triangle/square outputs from Analog Devices. Key Features Low power consumption, high-performance sine/triangle/square outputs, capability for phase and frequency modulation, on-board comparator, and more. Interface I2C,SPI ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads 24AA64 datasheet Waveform 2 click 2D and 3D files Waveform 2 click example on Libstock Waveform 2 click schematic AD9834 datasheet ADM8829 datasheet THS4551 datasheet Powered by TCPDF (www.tcpdf.org)
MIKROE-4346 价格&库存
很抱歉,暂时无法提供与“MIKROE-4346”相匹配的价格&库存,您可以联系我们找货
