Pressure 14 Click
PID: MIKROE-4424
Pressure 14 Click is a compact add-on board that contains a board-mount pressure sensor.
This board features the ABP2LANT060PG2A3XX, a piezoresistive silicon pressure sensor
offering a digital output for reading pressure over the specified full-scale pressure span and a
temperature range from Honeywell Sensing and Productivity Solutions. This I2C configurable
sensor is calibrated and temperature compensated for sensor offset, sensitivity, temperature
effects, and accuracy errors, including non-linearity, repeatability, and hysteresis, using an onboard ASIC. This Click board™ is suitable for pressure measurements in automotive
applications, industrial and consumer applications.
Pressure 14 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Pressure
Applications
Can be used for pressure measurements in
automotive applications, industrial and
On-board modules
ABP2LANT060PG2A3XX - piezoresistive silicon
pressure sensor offering a digital output for
pressure span from Honeywell Sensing and
Key Features
Ultra-low power consumption, calibrated and
temperature compensated/amplified for
sensor offset, sensitivity, temperature effects,
high accuracy, liquid media capable, and
more.
Interface
I2C
ClickID
No
Compatibility
mikroBUS™
Click board size
S (28.6 x 25.4 mm)
Input Voltage
3.3V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
Pressure 14 click 2D and 3D files
ABP2LANT060PG2A3XX datasheet
Pressure 14 click example on Libstock
Pressure 14 click schematic
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4424”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+413.421051+53.65451
- 国内价格
- 1+386.72826
- 5+378.99078
