MIKROE-4450
MIKROE-4450
    MIKRO
    CS3310,LT3032 放大器 音频 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4450 数据手册
Volume Click PID: MIKROE-4450 Volume Click is a compact add-on board that provides the user with complete digital volume control. This board features the CS3310, a stereo digital volume control designed specifically for audio systems from Cirrus Logic. It controls two independent low distortion audio channels with an adjustable range of 127 dB, in 0.5 dB steps achieved through 95.5 dB of attenuation and 31.5 dB of gain. It also contains a simple SPI serial interface that accepts 16-bit data, and offers low distortion and noise. This Click board™ represents a perfect solution for remote audio volume control applications Volume Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Signal Processing Applications Can be used for remote audio volume control applications. On-board modules - CS3310, a complete stereo digital volume control designed specifically for audio systems from Cirrus Logic - LT3032, a dual 150mA positive and negative low noise low dropout linear regulator with micropower quiescent current from Analog Devices. Key Features Complete digital volume control, wide adjustable range, low distortion, low noise active output stage capable of driving a 600Ω load, and more. Interface SPI ClickID No Compatibility mikroBUS™ Click board size L (57.15 x 25.4 mm) Input Voltage 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads CS3310 datasheet Volume click 2D and 3D files Volume click schematic Volume click example on Libstock LT3032 datasheet Powered by TCPDF (www.tcpdf.org)
MIKROE-4450 价格&库存
很抱歉,暂时无法提供与“MIKROE-4450”相匹配的价格&库存,您可以联系我们找货
MIKROE-4450
  • 1+499.421111+64.69250
