I2C MUX 5 Click
PID: MIKROE-4453
I2C MUX 5 Click is a compact add-on board with translating I2C and SMBus switch intended
for applications with I2C slave address conflicts. This board features the LTC4306, a 4-channel,
2-wire bus multiplexer with bus buffers to provide capacitive isolation between the upstream
and downstream buses from Analog Devices. Through software control, the LTC4306 splits the
I2C bus into four sub-branches and connects the upstream 2-wire bus to any desired
combination of downstream buses. It has a programmable disconnect from stuck bus function,
provides four alert inputs for fault reporting, and two GPIO pins configurable as inputs, opendrain, or push-pull outputs. This Click board™ is suitable for a wide range of applications from
industrial to medical, communications, and automotive systems.
I2C MUX 5 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
I2C
Applications
Can be used for a wide range of applications
from industrial to medical, communications,
On-board modules
I2C MUX 5 Click is based on the LTC4306, a
4-channel, 2-wire bus multiplexer with bus
the upstream and downstream buses from
Analog Devices.
Key Features
Multiplexer with capacitance buffering,
programmable disconnect from stuck bus,
compatible with I2C and SMBus standards,
several fault reporting pins, and more.
Interface
I2C
ClickID
No
Compatibility
mikroBUS™
Click board size
M (42.9 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
I2C MUX 5 click 2D and 3D files
LTC4306 datasheet
I2C MUX 5 click schematic
I2C MUX 5 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4453”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+256.593371+33.21334
