PAC1944 Click
PID: MIKROE-4478
PAC1944 Click is a compact add-on board that contains an energy monitoring solution. This
board features the PAC1944, a multi-channel DC power/energy monitor from Microchip
Technology. It uses real-time calibration to minimize offset and gain errors with no input filters
required for this device. One major feature of the PAC1944 design is a set of digital
comparators that allows the user to detect over/under voltage, over/undercurrent, and
overpower against user-programmed limits for each channel and generate an alert when the
threshold is exceeded. This Click board™ performs power calculations and energy
accumulation, enabling energy monitoring with integration periods up to one year or longer.
PAC1944 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Measurements
Applications
and energy accumulation, enabling energy
year or longer.
On-board modules
PAC1944 - four-channel, bidirectional, highside current-sensing solution with precision
voltage measurement capabilities, DSP for
power calculation and a power accumulator
from Microchip Technology
Key Features
High-side current monitor, real-time autocalibration of offset and gain errors for voltage
and current, 1% power measurement accuracy
over a wide dynamic range, alert feature, and
more.
Interface
I2C
ClickID
No
Compatibility
mikroBUS™
Click board size
M (42.9 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
PAC1944 click 2D and 3D files
PAC1944 datasheet
PAC1944 click schematic
PAC1944 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4478”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+183.66885
- 5+179.99276
