MIKROE-4496
MIKROE-4496
    MIKRO
    SHT40 湿度,温度 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4496 数据手册
Temp&Hum 15 Click PID: MIKROE-4496 Temp&Hum 15 Click is a compact add-on board that contains the 4th generation of best-inclass humidity sensing solution. This board features the SHT40, high-accuracy ultra-low-power 16-bit relative humidity and temperature sensor from Sensirion. It provides constant temperature accuracy, up to 0.1°C, and shows the best performance when operated within the recommended average temperature and humidity range of 5-60°C and 20-80%RH. The fully calibrated sensor offers linearized digital output, NIST traceability, and I2C Fast Mode Plus. It is reflow solderable and operational in condensing environments. This Click board™ is an ideal solution to be used in various temperature and humidity-related applications. Temp&Hum 15 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Temperature & humidity Applications Can be used in various temperature and humidity-related applications On-board modules SHT40 - high-accuracy ultra-low-power 16-bit relative humidity and temperature sensor from Sensirion Interface I2C ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads Temp&Hum 15 click 2D and 3D files SHT40 datasheet Temp&Hum 15 click schematic Temp&Hum 15 click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4496 价格&库存
很抱歉,暂时无法提供与“MIKROE-4496”相匹配的价格&库存,您可以联系我们找货
MIKROE-4496
  • 1+70.984391+9.16269
库存:12
MIKROE-4496
    • 1+63.87848
    • 5+62.59758
    库存:21
