MIKROE-4547
MIKROE-4547
    MIKRO
    TB67S539FTG 电机控制器/驱动器,步进 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4547 数据手册
Stepper 17 Click PID: MIKROE-4547 Stepper 17 Click is a compact add-on board that contains a bipolar stepper motor driver. This board features the TB67S539FTG, a two-phase bipolar stepping motor driver using a PWM chopper from Toshiba Semiconductor. It supports a PWM constant-current control drive without a current sense resistor for motor-current detection and full-step to 1/32 steps resolution for less motor noise and smoother control. It has a wide operating voltage range of 4.5V to 34V with an output current capacity of 1.8A maximum in addition to several anomaly detection indicators. This Click board™ makes the perfect solution for small stepping motors in a wide range of applications such as office automation, commercial and industrial equipment. Stepper 17 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Stepper Applications Can be used for small stepping motors in a wide range of applications such as office automation, commercial and industrial equipment On-board modules TB67S539FTG - two-phase bipolar stepping motor driver with resistorless current sensing from Toshiba Semiconductor Key Features Low power consumption, capable of controlling bipolar stepping motor, PWM controlled constant-current drive, operational in full, half, quarter, 1/8, 1/16, and 1/32 step resolutions, built-in a mixed decay mode, anomaly detection functions, and more Interface GPIO,I2C ClickID No Compatibility mikroBUS™ Click board size L (57.15 x 25.4 mm) Input Voltage 3.3V or 5V,External Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads MCP1501 datasheet TB67S539FTG datasheet PCA9555A datasheet Stepper 17 click schematic Stepper 17 click 2D and 3D files Stepper 17 click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4547 价格&库存
很抱歉,暂时无法提供与“MIKROE-4547”相匹配的价格&库存,您可以联系我们找货
MIKROE-4547
    • 1+251.16093
    • 5+238.60184
    库存:2
