MIKROE-4569
MIKROE-4569
    MIKRO
    TPS22918 机电元件 继电器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4569 数据手册
SolidSwitch Click PID: MIKROE-4569 SolidSwitch Click is a compact add-on board that contains load switch devices. This board features the TPS22918, four single-channel load switches from Texas Instruments. Every switch includes an N-channel MOSFET that operates over an input voltage range up to 5.5V and can support a maximum continuous current of 2 A. The switches are controlled by an ON/OFF input, performed by MAX7323, an I2C configurable port expander capable of interfacing directly with low-voltage control signals. This Click board™ is suitable for industrial systems, set-top boxes, electronic point of scale, and various other applications. SolidSwitch Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Relay Applications Can be used for industrial systems, set-top boxes, electronic point of scale, and various other applications. On-board modules TPS22918 - 5.5V 2A load switch from Texas Instruments Key Features Four integrated single channel load switches, flexible design, 2A maximum switch current, and more. Interface I2C ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V,External Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads SolidSwitch click 2D and 3D files TPS22918 datasheet MAX7323 datasheet SolidSwitch click schematic SolidSwitch click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4569 价格&库存
很抱歉,暂时无法提供与“MIKROE-4569”相匹配的价格&库存,您可以联系我们找货
MIKROE-4569
  • 1+366.101311+47.46000
