MIKROE-4594
MIKROE-4594
    MIKRO
    IQS525 电容式触控 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4594 数据手册
Touchpad 2 Click PID: MIKROE-4594 Touchpad 2 Click is a compact add-on board that easily integrates projected capacitive touch into their applications. This board features the IQS525, a projected capacitive touch and proximity trackpad/touchscreen controller from Azoteq. It features best in class sensitivity, signal-to-noise ratio, and automatic tuning of electrodes, in addition to the multi-touch and multi-hover feature. This Click board™ is characterized by embedded gesture engine recognition for simple gestures (tap, swipes, hold), as well as built-in noise detection and filtering. This Click board™ is suitable for human-machine interfaces, keypad or scrolling functions, single-finger gesture-based interfaces, and more. Touchpad 2 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Capacitive Applications Can be used for human-machine interfaces, keypad or scrolling functions, single-finger gesture-based interfaces, and more. On-board modules IQS525 - capacitive sensing controller designed for multitouch application using projected capacitance touch panel from Azoteq Key Features Multi-touch and multi-hover support, automatic drift compensation, embedded gesture engine recognition for simple gestures (tap, swipes, hold), and more. Interface I2C ClickID No Compatibility mikroBUS™ Click board size L (57.15 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads TouchPad 2 click schematic IQS525 datasheet TouchPad 2 click 2D and 3D files TouchPad 2 click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4594 价格&库存
很抱歉,暂时无法提供与“MIKROE-4594”相匹配的价格&库存,您可以联系我们找货
MIKROE-4594
    • 1+87.84072
    • 5+86.08078
    库存:16
    MIKROE-4594
    • 1+96.759901+12.51848
