MIKROE-4632
MIKROE-4632
    MIKRO
    TLI4971-A025T5 电流 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4632 数据手册
Hall Current 8 Click - 25A PID: MIKROE-4632 Hall Current 8 Click is a compact add-on board that contains a precise solution for AC/DC current sensing. This board features the TLI4971-A025T5, a high-precision coreless current sensor for industrial/consumer applications from Infineon Technologies. The TLI4971-A025T5 has an analog interface and two fast overcurrent detection outputs, which support the protection of the power circuitry. Galvanic isolation is also provided according to the magnetic sensing principle. Infineon's monolithic Hall technology enables accurate and highly linear measurement of currents with a full scale up to 25A. This Click board™ is suitable for AC/DC current measurement applications: electrical drives, general-purpose inverters, chargers, current monitoring, overload, over-current detection, and many more. Hall Current 8 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Current sensor,Measurements Applications Can be used for AC/DC current measurement applications: electrical drives, general-purpose inverters, chargers, current monitoring, overload, over-current detection, and many more. On-board modules TLI4971-A025T5 - high-precision miniature coreless magnetic current sensor for AC and DC measurements up to 25A with an analog interface and two fast overcurrent detection outputs from Infineon Technologies Key Features High accurate, scalable, DC & AC current sensing, analog interface and two independent fast Over-Current Detection (OCD) outputs, very low sensitivity error over temperature, and more. Interface Analog ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads Hall Current 8 Click - 25A schematic TLI4971 datasheet Hall Current 8 Click - 25A 2D and 3D files Hall Current 8 Click - 25A example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4632 价格&库存
很抱歉,暂时无法提供与“MIKROE-4632”相匹配的价格&库存,您可以联系我们找货
