NTAG 5 Link Click
PID: MIKROE-4635
NTAG 5 Link Click is a compact add-on board that acts as a bridge between an NFC-enabled
device and any I2C slave, such as a sensor or external memory. This board features the
NTP5332, a highly integrated NFC IC which creates a secure standard-based link from the
device to the cloud from NXP Semiconductors. Based on the NTAG 5 switch and operating at
13.56MHz, the NTP5332 represents an NFC Forum-compliant contactless tag that can be read
and written by an NFC-enabled device at close range and by an ISO/IEC 15693-enabled
industrial reader over a more extended range. It also incorporates an I2C interface with an I2C
master features and AES mutual authentication, SRAM memory, and energy harvesting
possibility, which means it can supply power to other components in the system. This Click
board™ is optimized for sensor-driven applications and represents an ideal solution for rapidly
integrating NFC technology in any custom application.
NTAG 5 Link Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
RFID/NFC
Applications
Can be used for sensor-driven applications and
application
On-board modules
NTP5332 - highly integrated NFC IC which
Key Features
NFC Forum Type 5 Tag compliant, host
interface configurable as an I2C master/slave,
32-byte reprogrammable originality signature,
AES mutual authentication, event detection,
energy harvest feature, and more
Interface
I2C
ClickID
No
Compatibility
mikroBUS™
Click board size
L (57.15 x 25.4 mm)
Input Voltage
3.3V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
NTAG 5 Link click example on Libstock
NTAG 5 Link click schematic
NTAG 5 Link click 2D and 3D files
NTP5332 datasheet
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4635”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+123.461961+16.05346
- 国内价格 香港价格
- 1+120.102251+15.61660
