MIKROE-4733
MIKROE-4733
    MIKRO
    WSEN-HIDS 湿度,温度 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4733 数据手册
Temp&Hum 16 Click PID: MIKROE-4733 Temp&Hum 16 Click is a compact add-on board that represents temperature and humidity sensing solutions. This board features the WSEN-HIDS (2525020210001), a MEMS-based capacitive humidity sensor with an integrated ASIC and I2C and SPI serial communication from Würth Elektronik. A silicon-based temperature sensor is also integrated within the same package. ASIC contains the multiplier, operational amplifier, analog-to-digital converter, and other signal conditioning blocks like controller logics and interrupts. It converts the analog signal from humidity and temperature sensing elements into 16-bit digital humidity and temperature values. The WSEN-HIDS is factory calibrated for both humidity and temperature measurements with no further calibration required. This Click board™ is an ideal solution to be used in various temperature and humidity-related applications. Temp&Hum 16 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Temperature & humidity Applications This Click board™ is an ideal solution to be used in various temperature and humidityrelated applications On-board modules WSEN-HIDS (2525020210001) - MEMS-based capacitive humidity sensor with an integrated ASIC and I2C and SPI serial communication from Würth Elektronik Key Features Low power consumption, high performance, digital output interface, embedded temperature sensor for ambient temperature measurement, fully calibrated, and more. Interface I2C,SPI ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads Temp&Hum 16 click 2D and 3D files Temp&Hum 16 click schematic WSEN-HIDS(282525020210001) datasheet Temp&Hum 16 click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4733 价格&库存
很抱歉,暂时无法提供与“MIKROE-4733”相匹配的价格&库存,您可以联系我们找货
MIKROE-4733
    • 1+143.74220
    • 5+140.86798
    库存:15
    MIKROE-4733
    • 1+158.667231+20.52784
    MIKROE-4733
    • 1+153.653201+19.56970
    库存:6
