Brushless 16 Click
PID: MIKROE-4742
Brushless 16 Click is a compact add-on board suitable for controlling BLDC motors with any
MCU. This board features the LB11685AV, a three-phase full-wave current-linear-drive motor
driver from ON Semiconductor. It adopts a sensorless control system without the use of a Hall
Effect device. The LB11685AV features a current soft switching circuit for quieter operation and
is optimal for driving the cooling fan motors used in refrigerators. It also comes with several
protection features such as motor lock, thermal shutdown, current limit, beat lock detection,
and more. This Click board™ makes the perfect solution for use in home appliances such as airconditioner and cooling fans, air purifiers, and industrial equipment.
Brushless 16 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Brushless
Applications
Can be used for use in home appliances such
as air-conditioner and cooling fans, air
On-board modules
LB11685AV - three-phase full-wave currentlinear-drive motor driver from ON
Semiconductor
Key Features
Low power consumption, Hall-senor less, easy
control, protection features (current limit, lock
detection, thermal protection), stability at
booting, and more
Interface
GPIO
ClickID
No
Compatibility
mikroBUS™
Click board size
M (42.9 x 25.4 mm)
Input Voltage
3.3V or 5V,External
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
Brushless 16 click 2D and 3D files
LB11685AV datasheet
Brushless 16 click schematic
Brushless 16 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4742”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+143.713131+18.65630
