8800 Retro Click
PID: MIKROE-4771
8800 Retro Click is a compact add-on board that simplifies the control of multiple LEDs. This
board features the AS1115, compact LED driver for 8x8 display screen programmed via a
compatible 2-wire I2C interface from ASM-AG. The AS1115 includes an integrated BCD codeB/HEX decoder, multiplex scan circuitry, segment and display drivers, and 64-bit memory.
Internal memory stores the shift register settings, eliminating the need for continuous device
reprogramming. All outputs of the AS1115 can be configured for key-readback, where keyswitch status is obtained by polling for up to 64 keys, while 16 keys can be used to trigger an
interrupt. This Click board™ is suitable for seven-segment or dot matrix user-interface displays
and other white goods or personal electronic applications.
8800 Retro Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
LED Matrix,Pushbutton/Switches
Applications
Can be used for seven-segment or dot matrix
user-interface displays and other white goods
On-board modules
AS1115 - compact LED driver for 8x8 display
screen programmed via a compatible 2-wire
Key Features
Low power consumption, individual LED
segment control, readback for 16 buttons,
interrupt feature, LED error detection, low
power shutdown current, software reset, and
more
Interface
I2C
ClickID
No
Compatibility
mikroBUS™
Click board size
L (57.15 x 25.4 mm)
Input Voltage
3.3V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
8800 Retro click schematic
AS1115 datasheet
8800 Retro click 2D and 3D files
8800 Retro click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4771”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+246.657961+30.69399
