MIKROE-4786
MIKROE-4786
    MIKRO
    TB9051FTG 电机控制器/驱动器 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4786 数据手册
DC Motor 18 Click PID: MIKROE-4786 DC Motor 18 Click is a compact add-on board that contains a brushed DC motor driver. This board features the TB9051FTG, an automotive PWM-type single-channel H-Bridge DC brushed motor driver from Toshiba Semiconductor. The Forward/Reverse/Brake mode can be selected according to PWM control signals, while the motor operation and stop mode can be chosen by an enable pin. It has a wide operating voltage range of 4.5V to 28V with an output current capacity of 5A max. Besides, it also features built-in protection against under-voltage, overcurrent, and overtemperature conditions. This Click board™ is suitable for various automotive applications such as throttle and valve control, various engine bulbs, storing of door mirrors, and seat positioning. DC Motor 18 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Brushed Applications Can be used for various automotive applications such as throttle and valve control, various engine bulbs, storing of door mirrors, and seat positioning On-board modules TB9051FTG - motor driver which incorporates the output driver for the direct drive of a DC brushed motor intended for automotive use from Toshiba Semiconductor Key Features Key Features Low power consumption, ultra low on-resistance, anomaly detection features, selectable motor operation, PWM control, highside current monitoring, diagnosis indicator, and more. Interface Analog,GPIO,PWM ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads DC Motor 18 click schematic TB9051FTG datasheet DC Motor 18 click 2D and 3D files DC Motor 18 click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4786 价格&库存
很抱歉,暂时无法提供与“MIKROE-4786”相匹配的价格&库存,您可以联系我们找货
MIKROE-4786
    • 1+143.74220
    • 5+140.86798
    库存:16
    MIKROE-4786
    • 1+158.885471+20.54822
    库存:5
