MIKROE-4787
MIKROE-4787
    MIKRO
    TLC59283 LED 驱动器 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4787 数据手册
LED Driver 10 Click PID: MIKROE-4787 LED Driver 10 Click is a compact add-on board that simplifies the control of multiple LEDs. This board features the TLC59283, a 16-channel, constant-current sink light-emitting diode (LED) driver with pre-charge FET from Texas Instruments. Each LED channel can be individually controlled with a simple SPI serial communication protocol compatible with both 3.3V or 5V logic levels. Each constant-current output has a pre-charge field-effect transistor that can reduce ghosting on the multiplexing drive LED display. It has additional features such as switching off all outputs via just one mikroBUS™ pin and setting the constant-current values on all 16 channels via one onboard potentiometer. This Click board™ is suitable for color mixing and backlight application for amusement products, LED status signalization, home automation projects, and many more. LED Driver 10 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type LED Drivers Applications Can be used for color mixing and backlight application for amusement products, LED status signalization, home automation projects, and many more On-board modules TLC59283 - SPI bus controlled, 16-channel, constant-current sink light-emitting diode (LED) driver with pre-charge FET from Texas Instruments Key Features Low power consumption, 16 channels, ON/OFF LED channels control, pre-charge FET for ghosting reduction, switching delay for noise reduction, channel-current setting, and more Interface SPI ClickID No Compatibility mikroBUS™ Click board size L (57.15 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads TLC59283 datasheet LED Driver 10 click 2D and 3D files LED Driver 10 click schematic LED Driver 10 click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4787 价格&库存
很抱歉,暂时无法提供与“MIKROE-4787”相匹配的价格&库存,您可以联系我们找货
MIKROE-4787
  • 1+151.423771+19.68460
