Analog MUX 4 Click
PID: MIKROE-4795
Analog MUX 4 Click is a compact add-on board that switches one of many analog inputs to
one digital output. This board features the TMUX1308, a general-purpose 8:1 single-ended
CMOS multiplexer (MUX) from Texas Instruments. The TMUX1308 has an internal injection
current control which eliminates the need for external diode and resistor networks to protect
the switch and keep the input signals within the supply voltage. It also supports bidirectional
analog and digital signals ranging from 0 to 5V, alongside several protection features allowing
a reliable operation and protecting the device from potential damage. This Click board™ is
suitable for various applications, from industrial to instrumentation, consumer,
communications, and more.
Analog MUX 4 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Measurements,Port expander
Applications
Can be used for various applications, from
On-board modules
TMUX1308 - general-purpose 8:1 single-ended
CMOS analog multiplexer from Texas
Instruments
Key Features
Injection current control, back-powering
protection, bidirectional signal path, BreakBefore-Make switching, VCC range signal
handling, TTL/CMOS-logic compatible, pincontrollable, and more
Interface
Analog,GPIO
ClickID
No
Compatibility
mikroBUS™
Click board size
L (57.15 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
Analog MUX 4 click example on Libstock
TMUX1308 datasheet
Analog MUX 4 click schematic
Analog MUX 4 click 2D and 3D files
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4795”相匹配的价格&库存,您可以联系我们找货
