GainAMP 3 Click
PID: MIKROE-4800
GainAMP 3 Click is a compact add-on board that contains a 4-channel programmable gain
amplifier. This board features the ADA4254, a zero drift, high voltage, programmable gain
instrumentation amplifier from Analog Devices. It features 12 binary weighted gains and three
scaling gain options resulting in 36 possible gain settings. It comes with an input multiplexer
providing ±60V protection to the high impedance inputs of the amplifier and an excitation
current source output available to bias sensors such as resistance temperature detectors
(RTDs). The ADA4254 zero-drift amplifier topology self-calibrates DC errors and low-frequency
noise, achieving excellent DC precision over the entire specified temperature range,
maximizing dynamic range, and significantly reducing calibration requirements in many
applications. This Click board™ represents a perfect choice for industrial systems and process
control that demand precision, robustness, and low power, thanks to its low power
consumption.
GainAMP 3 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Amplifier
Applications
Can be used for industrial systems and
process control that demand precision,
power consumption
On-board modules
ADA4254 - zero drift, high voltage,
programmable gain instrumentation amplifier
(PGIA) designed for process control and
industrial applications from Analog Devices
Key Features
Low power consumption, optimized for ADC
synchronization, 12 binary steps and 3 scaling
gains, ±60V protection input mux, excellent
DC precision, and more
Interface
SPI
ClickID
No
Compatibility
mikroBUS™
Click board size
L (57.15 x 25.4 mm)
Input Voltage
3.3V or 5V,External
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
GainAMP 3 click example on Libstock
GainAMP 3 click 2D and 3D files
GainAMP 3 click schematic
ADA4254 datasheet
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4800”相匹配的价格&库存,您可以联系我们找货
