MIKROE-4822
MIKROE-4822
    MIKRO
    VL53L1 光,3D 飞行时间(ToF) 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4822 数据手册
Proximity 15 Click PID: MIKROE-4822 Proximity 15 Click is a compact add-on board that contains a close-range proximity sensing solution. This board features the VL53L1, a state-of-the-art, Time-of-Flight (ToF), a laserranging miniature sensor from STMicroelectronics. The VL53L1 allows absolute distance measurement, whatever the target color and reflectance. It integrates a SPAD (single-photon avalanche diode) array, physical infrared filters, and optics to achieve the best-ranging performance in various ambient lighting conditions, with a wide range of cover windows. It provides accurate ranging above 4m and can work at fast speeds (60Hz). With patented algorithms and ingenious module construction, the VL53L1 is also able to detect different objects within the field of view and scene browsing and multi-zone detection. This Click board™ is suitable for consumer and industrial applications such as multi-object detection and multiarray scanning. Proximity 15 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Proximity Applications Can be used for consumer and industrial applications such as multi-object detection and multi-array scanning On-board modules VL53L1 - third-generation time-of-flight (ToF) laser-ranging sensor from STMicroelectronics Key Features Low power consumption, fast accurate distance ranging, 400cm+ detection with full field of view, multi-object detection, multi-zone scanning, shutdown and interrupt feature, works with many types of cover glass, and more Interface I2C ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads Proximity 15 click example on Libstock Proximity 15 click 2D and 3D files VL53L1 datasheet Proximity 15 click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4822 价格&库存
很抱歉,暂时无法提供与“MIKROE-4822”相匹配的价格&库存,您可以联系我们找货
