MIKROE-4846
MIKROE-4846
    MIKRO
    TPS62912 电源 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4846 数据手册
Buck 16 Click PID: MIKROE-4846 Buck 16 Click is a compact add-on board that contains a DC-DC power converter that steps down the voltage from its input to its output. This board features the TPS62912, a highefficiency, low noise, and low ripple current-mode synchronous buck converter from Texas Instruments. The TPS62912 has an output-voltage error of less than 1%, which helps ensure tight output-voltage accuracy, operates at a fixed switching frequency of 2.2MHz or 1MHz, and allows synchronization to an external clock. This Click board™ is suitable for noise-sensitive applications that generally use an LDO for post-regulation, such as high-speed ADCs, clock and jitter cleaner, serializer, de-serializer, and radar applications. Buck 16 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Buck Applications Can be used for noise-sensitive applications that generally use an LDO for post-regulation, such as high-speed ADCs, clock and jitter cleaner, serializer, de-serializer, and radar applications On-board modules TPS62912 - low-noise, low-ripple synchronous buck converter with a fixed-frequency currentmode from Texas Instrument Key Features Low output noise and voltage ripple, 2.2MHz or 1MHz fixed frequency peak current mode control, synchronizable with external clock, output voltage accuracy of ±1%, power-good output, and more Interface GPIO,SPI ClickID No Compatibility mikroBUS™ Click board size L (57.15 x 25.4 mm) Input Voltage 3.3V or 5V,External Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads Buck 16 click 2D and 3D files MCP4161 datasheet TPS62912 datasheet Buck 16 click schematic Buck 16 click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4846 价格&库存
很抱歉,暂时无法提供与“MIKROE-4846”相匹配的价格&库存,您可以联系我们找货
MIKROE-4846
  • 1+235.331801+30.44650
库存:18
