MIKROE-4875
MIKROE-4875
    MIKRO
    KP236 压力 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4875 数据手册
Altitude 5 Click PID: MIKROE-4875 Altitude 5 Click is a compact add-on board allowing high-resolution barometric pressure measurement. This board features the KP236, an analog barometric air pressure sensor based on a capacitive principle from Infineon Technologies. The KP236 is primarily developed for measuring barometric air pressure but can also be used in other application fields. It is surface micro-machined with a monolithic integrated signal conditioning circuit implemented in BiCMOS technology. The calibrated transfer function converts pressure into an analog output signal in a range of 40kPa to 115kPa. However, the choice of signal processing is up to the user; more precisely, the user can process the output signal in analog or digital form. The high accuracy and the high sensitivity of the KP236 make this Click board™ suitable for advanced automotive applications and industrial and consumer applications. Altitude 5 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Pressure Applications Can be used for advanced automotive applications and industrial and consumer applications On-board modules KP236 - high-resolution analog barometric air pressure sensor based on a capacitive principle from Infineon Technologies Key Features High precision pressure measurements, high accuracy, automotive qualified, wide temperature range, possibility of signal processing in analog and digital form, and more Interface Analog,I2C ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads MCP3221 datasheet KP236 datasheet Altitude 5 click 2D and 3D files Altitude 5 click schematic Altitude 5 click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4875 价格&库存
很抱歉,暂时无法提供与“MIKROE-4875”相匹配的价格&库存,您可以联系我们找货
MIKROE-4875
    • 1+217.29513
    • 5+212.94214
    库存:4
    MIKROE-4875
    • 1+255.446121+33.11068
    库存:1
