MIKROE-4876
MIKROE-4876
    MIKRO
    ADXL363 加速计,温度 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4876 数据手册
Accel 16 Click PID: MIKROE-4876 Accel 16 Click is a compact add-on board that contains an acceleration sensor. This board features the ADXL363, a micropower three-sensor combination including acceleration and temperature from Analog Devices. This device combines a 3-axis MEMS accelerometer, a temperature sensor, and an analog-to-digital converter (ADC) input for synchronized conversions of external signals. It allows selectable full-scale acceleration measurements in ranges of ±2g, ±4g, and ±8g (with a resolution of 1mg/LSB on the ±2g range), and communicates via SPI serial interface providing 12-bit output resolution for all three sensors. This Click board™ is suitable for various applications such as vibration and condition monitoring, test and measurements, predictive maintenance, and more. Accel 16 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Motion Applications Can be used for various applications such as vibration and condition monitoring, test and measurements, predictive maintenance, and more On-board modules ADXL363 - micropower complete sensor suite consisting of an accelerometer, an ADC for synchronous conversion of input from a third sensor, and a temperature sensor from Analog Devices Key Features Accelerometer, temperature sensor, and provision for third analog sensor input, low power consumption, all sensors sampled synchronously, 12-bit resolution for all sensors, built-in features for motion-based system level power savings, and more Interface SPI ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads Accel 16 click 2D and 3D files Accel 16 click schematic ADXL363 datasheet Accel 16 click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4876 价格&库存
很抱歉,暂时无法提供与“MIKROE-4876”相匹配的价格&库存,您可以联系我们找货
MIKROE-4876
  • 1+174.836621+21.92485
库存:4
MIKROE-4876
    • 1+159.71702
    • 5+156.51997
    库存:10
