Thermo 21 Click
PID: MIKROE-4879
Thermo 21 Click is a compact add-on board that provides an accurate temperature
measurement. This board features the ADT7301, a high-precision digital temperature sensor
from Analog Devices. The ADT7301 houses an on-chip temperature sensor, a 13-bit A/D
converter, a reference circuit, and serial interface logic functions in one package. Characterized
by its high accuracy (up to ±0.5°C typical) and high resolution of 0.03125°C, this temperature
sensor provides temperature data to the host controller with a configurable SPI interface. This
Click board™ is appropriate for process control, environmental monitoring, domestic
appliances, electronic test equipment, or other temperature measurement applications.
Thermo 21 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Temperature & humidity
Applications
Can be used for process control,
On-board modules
ADT7301 - high-precision digital temperature
sensor from Analog Devices
Key Features
Low power consumption, high precission and
accuracy, 13-bit temperature-to-digital
converter, 0.03125°C temperature resolution,
SPI compatible serial interface, Shutdown
mode, and more
Interface
SPI
ClickID
No
Compatibility
mikroBUS™
Click board size
S (28.6 x 25.4 mm)
Input Voltage
3.3V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
Thermo 21 click 2D and 3D files
Thermo 21 click schematic
ADT7301 datasheet
Thermo 21 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4879”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+194.063671+25.22765
- 国内价格
- 1+169.17279
- 5+165.79870
- 国内价格 香港价格
- 1+188.714701+24.53230
