Expand 13 Click
PID: MIKROE-4887
Expand 13 Click is a compact add-on board that contains a multi-port I/O expander. This
board features the PI4IOE5V96248, a 48-bit general-purpose I/O expander providing remote I/O
expansion for most MCU’s families from Diodes Incorporated. The PI4IOE5V96248 comes in a
6-channel configuration and allows easy addition of I/O through a standard I2C serial interface.
It has a built-in level shifting feature that makes it highly flexible in power supply systems
where communication between incompatible I/O voltages is required. It also contains a reset
and interrupts feature that informs the MCU of incoming data on its ports without
communicating via the serial bus. This Click board™ provides a simple solution when additional
I/Os are needed while keeping interconnections to a minimum in system monitoring
applications, industrial controllers, portable equipment, and many more.
Expand 13 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Port expander
Applications
Can be used in system monitoring
On-board modules
PI4IOE5V96248 - 48-bit low-voltage translating
general-purpose remote I/O expander from
Diodes Incorporated
Key Features
Remote I/O pins that default to inputs at PowerUp, compliant with the I2C-bus Fast and
Standard modes, 5V tolerant I/Os, 25mA sink
capability for directly driving LEDs,
programmable slave addresses, and more
Interface
I2C
ClickID
No
Compatibility
mikroBUS™
Click board size
L (57.15 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
Expand 13 click 2D and 3D files
PI4IOE5V96248 datasheet
Expand 13 click schematic
Expand 13 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4887”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+143.74220
- 5+140.86798
- 国内价格 香港价格
- 1+146.381601+18.92750
