Accel 20 Click
PID: MIKROE-4888
Accel 20 Click is a compact add-on board that contains an acceleration sensor. This board
features the KX134-1211, a digital output 3-axis accelerometer optimized for machine
condition monitoring from Rohm Semiconductor. It allows selectable full-scale acceleration
measurements in ranges of ±8g, ±16g, ±32g, or ±64g in three axes with a configurable host
interface that supports both SPI and I2C serial communication. It also features an Advanced
Data Path (ADP) technology which allows noise filtering and sensor signal processing, usually
carried out by the MCU, to be performed by the accelerometer. They contribute to reducing
MCU load and power consumption together with improved application performance. This Click
board™ is suitable for various applications such as vibration and condition monitoring, test and
measurements, predictive maintenance, and more.
Accel 20 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Motion
Applications
Can be used for various applications such as
more
On-board modules
KX134-1211 - highly reliable digital triaxial
acceleration sensor with a feature set
optimized for machine condition monitoring
Key Features
Low power consumption, high performance
and resolution, high reliability, userconfigurable 3-stage Advanced Data Path
(ADP), integrated interrupt features, Excellent
temperature performance with high shock
survivability, selectable serial interface, and
more
Interface
I2C,SPI
ClickID
No
Compatibility
mikroBUS™
Click board size
S (28.6 x 25.4 mm)
Input Voltage
3.3V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
Accel 20 click example on Libstock
KX134-1211 datasheet
Accel 20 click schematic
Accel 20 click 2D and 3D files
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4888”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+299.62692
- 5+293.63897
