Environment 3 Click
PID: MIKROE-4893
Environment 3 Click is a compact add-on board that contains a four-in-one environmental
measurement solution. This board features BME688, a first gas sensor with Artificial
Intelligence (AI), and integrated high-linearity/high-accuracy pressure, humidity, and
temperature sensors from Bosch Sensortec. The BME688 can detect Volatile Organic
Compounds (VOCs), Volatile Sulfur Compounds (VSCs), and other gases such as carbon
monoxide and hydrogen in part per billion (ppb) range. It provides absolute temperature
accuracy, typical of ±1°C, and best performance when operated within the pressure,
temperature, and humidity range of 300-110hPa, 0-65°C, and 10-90%RH. Also, it comes with a
configurable host interface that supports both SPI and I2C serial communication. This Click
board™ is suitable for indoor and outdoor air quality measurement, detection of unusual gases
and smells, and various temperature and humidity-related applications.
Environment 3 Click is supported by a mikroSDK compliant library, which includes functions
that simplify software development. This Click board™ comes as a fully tested product, ready
to be used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Environmental
Applications
Can be used for indoor and outdoor air quality
measurement, detection of unusual gases and
smells, and various temperature and humidityrelated applications
On-board modules
BME688 - air quality MEMS sensor that
combines gas, humidity, temperature, and
barometric pressure sensing from Bosch
Sensortech
Key Features
Four-in-one environmental measurement
solution, wide-ranging gas detection, highlinearity, high-accuracy and precision, low
power consumption, configurable host
interface, and more
Interface
I2C,SPI
ClickID
No
Compatibility
mikroBUS™
Click board size
S (28.6 x 25.4 mm)
Input Voltage
3.3V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
Environment 3 click example on Libstock
Environment 3 click schematic
BME688 datasheet
Environment 3 click 2D and 3D files
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4893”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+231.52043
- 5+226.88627
