PAC1720 Click
PID: MIKROE-4905
PAC1720 Click is a compact add-on board that contains an energy monitoring solution. This
board features the PAC1720, an I2C configurable dual high-side bidirectional current sensing
monitor with precision voltage measurement capabilities from Microchip Technology. The
PAC1720 measures the voltage developed across external sense resistors to represent the highside current of a battery or voltage regulator. They also measure the SENSE+ pin voltage and
use these estimated values to present a proportional average power calculation. The current
sensing feature includes fault protection, where during a fault condition, the ALERT pin can be
asserted or masked. This Click board™ performs power calculations enabling energy
monitoring in industrial and embedded applications, power management systems, and many
more.
PAC1720 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Measurements
Applications
Can perform power calculations enabling
energy monitoring in industrial and embedded
and many more
On-board modules
PAC1720 - dual bidirectional high-side currentsensing device with precision voltage
Technology
Key Features
Dual high-side bidirectional current sensor,
power calculation, programmable sense
voltage range, fault event indicator, I2C
interface with selectable address, and more
Interface
I2C
ClickID
No
Compatibility
mikroBUS™
Click board size
M (42.9 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
PAC1720 click 2D and 3D files
PAC1720 datasheet
PAC1720 click example on Libstock
PAC1720 click schematic
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4905”相匹配的价格&库存,您可以联系我们找货
