MIKROE-4907
MIKROE-4907
    MIKRO
    CC2D23 湿度,温度 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4907 数据手册
Temp&Hum 20 Click PID: MIKROE-4907 Temp&Hum 20 Click is a compact add-on board that represents temperature and humidity sensing solution. This board features the CC2D23, a highly accurate, fully-calibrated relative humidity and temperature sensor from Amphenol. This sensor, characterized by its high accuracy (±2% from 20% to 80%RH (±3% over entire humidity range)) and high resolution, provides factory-calibrated 14-bit data to the host controller with a configurable I2C interface. It also comes with alarm features for preset control at a minimum and maximum humidity. The long-term stability and reliability, alongside other features, make this Click board™ ideal for various temperature and humidity-related applications and a vast number of applications ranging from portable devices to products designed for harsh environments. Temp&Hum 20 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Temperature & humidity Applications Can be used for various temperature and humidity-related applications and a vast number of applications ranging from portable devices to products designed for harsh environments On-board modules CC2D23 - highly accurate, fully-calibrated relative humidity and temperature sensor from Amphenol Key Features Low power consumption, fully-calibrated and temperature-compensated, high precision and accuracy, I2C interface with alarm functions, reliable in harsh environments, and more Interface I2C ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads Temp&Hum 20 click example on Libstock Temp&Hum 20 click 2D and 3D files SiP32431DN datasheet CC2D23 datasheet Temp&Hum 20 click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4907 价格&库存
很抱歉,暂时无法提供与“MIKROE-4907”相匹配的价格&库存,您可以联系我们找货
MIKROE-4907
  • 1+274.509911+35.68540
MIKROE-4907
    • 1+245.97484
    • 5+241.04909
    库存:8
    MIKROE-4907
    • 1+282.268611+36.69401
    库存:3
