MIKROE-4911
MIKROE-4911
    MIKRO
    GUVA-C32SM 紫外线(UV) 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4911 数据手册
UVA Click PID: MIKROE-4911 UVA Click is a compact add-on board used to detect solar UV index. This board features the GUVA-C32SM, an ultraviolet light sensor capable of measuring UV index between 0 to 14 from Genicom Co., Ltd. It contains the GaN-based chip die, amplifiers, ADC, digital control logic, and I2C interface circuit to measure UVA volumes, working in the spectral range of 220-370nm. The GUVA-C32M can acquire the intensity of UVA, respectively, and outputs digital count according to each intensity. By using the available power management mode properly according to the work to be done, the power consumption can be reduced. This Click board™ is suitable for various applications, such as determining exposure to ultraviolet radiation in a laboratory or environmental settings, weather stations, industrial manufacturing, and many more. UVA Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Optical Applications Can be used in applications such as determining exposure to ultraviolet radiation in a laboratory or environmental settings, weather stations, industrial manufacturing, and many more On-board modules GUVA-C32SM - ultraviolet light sensor capable of measuring UV index between 0 to 14 from Genicom Co., Ltd Key Features Integrated GaN Sensors for UVA, programmable gain and integration time, power management modes, I2C interface, and more Interface I2C ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads PCA9306 datasheet GUVA-C32SM datasheet UVA click 2D and 3D files UVA click schematic UVA click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4911 价格&库存
很抱歉,暂时无法提供与“MIKROE-4911”相匹配的价格&库存,您可以联系我们找货
