MIKROE-4933
MIKROE-4933
    MIKRO
    BH1726NUC 光 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4933 数据手册
Ambient 16 Click PID: MIKROE-4933 Ambient 16 Click is a compact add-on board used to measure the amount of the present ambient light. This board features the BH1726NUC, a 16-bit digital-output ambient light sensor with an I2C interface from Rohm Semiconductor. The BH1726NUC can detect a wide range of illuminance up to 30klx and provides excellent responsivity close to the human eyes' response. It is designed to control the brightness in various applications based on ambient light availability, brightness for optimum visibility, and energy efficiency. Operation in a temperature range of -40°C to 85°C ensures stable operation under extreme conditions. This Click board™ is the most suitable for obtaining ambient light data for adjusting brightness in applications that require power saving and better visibility. Ambient 16 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Optical Applications Can be used for obtaining ambient light data for adjusting brightness in applications that require power saving and better visibility On-board modules BH1726NUC - 16-bit digital-output ambient light sensor from Rohm Semiconductor Key Features Low power consumption, corresponds to a dark window because of high sensitivity, close responsivity to the human eye, I2C interface with selectable slave address, wide illumination range, stable performance over temperature and voltage, and more Interface I2C ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads Ambient 16 Click schematic BH1726NUC datasheet Ambient 16 click 2D and 3D files Ambient 16 click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4933 价格&库存
很抱歉,暂时无法提供与“MIKROE-4933”相匹配的价格&库存,您可以联系我们找货
