Current Limit 6 Click
PID: MIKROE-4915
Current Limit 6 Click is a compact add-on board representing a current-limiting solution. This
board features the MAX17608, adjustable overvoltage, and overcurrent protection device
from Analog Devices. This Click board™ is ideal for protecting systems with the flexible input
overvoltage protection range from 4.5V to 60V, and the adjustable input undervoltage
protection range is 4.5V to 59V. Also, the maximum current limit is 1A and can be programmed
through a digital potentiometer MAX5401. When the device current reaches the programmed
threshold, the device prevents further current increases by modulating the FET resistance. This
Click board™ is suitable for applications in portable equipment, process instrumentation, and
condition monitoring, or with power supplies, protecting them in a short circuit or other
overload conditions.
Current Limit 6 Click is supported by a mikroSDK compliant library, which includes functions
that simplify software development. This Click board™ comes as a fully tested product, ready
to be used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Power Switch
Applications
Can be used for applications in portable
overload conditions
On-board modules
MAX17608 - current-limiting device with an
adjustable overvoltage and overcurrent
protection feature from Maxim Integrated, now
part of Analog Devices
Key Features
OVLO/UVLO and reverse voltage protection,
programmable current limiting up to 1A, wide
input-supply range up to 60V, thermal
overload protection, operational and fault
signals indicators, and more
Interface
GPIO,SPI
ClickID
No
Compatibility
mikroBUS™
Click board size
M (42.9 x 25.4 mm)
Input Voltage
3.3V or 5V,External
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
Current Limit 6 click 2D and 3D files
MAX5401 datasheet
MAX17608 datasheet
Current Limit 6 click example on Libstock
Current Limit 6 click schematic
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4915”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+255.833961+33.16096
