Pressure 17 Click
PID: MIKROE-4944
Pressure 17 Click is a compact add-on board that contains a board-mount pressure sensor.
This board features the BM1390GLV-Z, a high-precision piezoresistive pressure sensor from
Rohm Semiconductor. The BM1390GLV-Z comes with a configurable host interface that
supports I2C serial communication and measures pressure in a range from 300hPa up to
1300hPa with an accuracy of ±1hPa. It also has a built-in temperature compensation function
that internally performs temperature compensation for MEMS inside the chip, so it’s easy to get
pressure information, built-in FIFO, and operation in a temperature range of -40°C to 85°C,
which ensures stable operation under extreme conditions. This Click board™ is suitable for
pressure measurements in automotive applications, industrial and consumer applications.
Pressure 17 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Pressure
Applications
Can be used for pressure measurements in
On-board modules
BM1390GLV-Z - ultra-compact piezoresistive
pressure sensor from Rohm Semiconductor
Key Features
Low power consumption, high precission,
MEMS based piezo-resistive sensing principle,
built-in temperature compensation function,
interrupt feature, and more
Interface
I2C
ClickID
No
Compatibility
mikroBUS™
Click board size
S (28.6 x 25.4 mm)
Input Voltage
3.3V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
BM1390GLV-Z datasheet
Pressure 17 click 2D and 3D files
Pressure 17 click schematic
Pressure 17 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
