3D Hall 9 Click
PID: MIKROE-4948
3D Hall 9 Click is a compact add-on board used to detect the strength of a magnetic field in
all three dimensions. This board features the ALS31300, a 3D linear Hall-effect sensor with
digital output and advanced low power management from Allegro Microsystems. The ALS31300
features an I2C interface, enabling it to be easily configured by MCU with the measurement
data provided in digital format of 12-bits corresponding to the magnetic field measured in each
X, Y, and Z axes. It also provides the ability to set different I2C slave addresses (16 unique
addresses) by populating the appropriate resistors desired by the user. Power management of
the ALS31300 is highly configurable, allowing for system-level optimization of supply current
and performance. This Click board™ is suitable for various applications, such as 3D sensing for
head-on linear motion, slide-by position sensing, and rotation angle measurements.
3D Hall 9 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Magnetic
Applications
Can be used for various applications, such as
3D sensing for head-on linear motion, slide-by
measurements
On-board modules
ALS31300 - 3D linear Hall-effect sensor used
to detect the strength of a magnetic field in all
three dimensions (X, Y, and Z axes) from
Key Features
Low power consumption, 1% accurate factorytrimmed sensitivity ±500 G, integrated
temperature sensor, I2C interface with
selectable slave addresses, and more
Interface
I2C
ClickID
No
Compatibility
mikroBUS™
Click board size
S (28.6 x 25.4 mm)
Input Voltage
3.3V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
ALS31300 datasheet
NCP170 datasheet
3D Hall 9 click 2D and 3D files
3D Hall 9 click schematic
3D Hall 9 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4948”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+146.60600
- 5+143.66930
