MIKROE-4984
MIKROE-4984
    MIKRO
    PIC32MZ2048EFH144 用于 PIC32MZ CAPACITIVE FPI 的 mikromedia 4,带边框 PIC® PIC32 MCU 32-位 评估板 - 嵌入式
MIKROE-4984 数据手册
Mikromedia 4 for PIC32MZ Capacitive FPI with bezel PID: MIKROE-4984 Rich with peripherals Mikromedia 4 for PIC32MZ CAPACITIVE FPI with bezel is not limited to multimedia-based applications only. USB, digital motion sensor, battery charging functionality, SD card reader and much more expands its use beyond the multimedia. Mikromedia 4 for PIC32MZ CAPACITIVE FPI with bezel has two mikroBUS™ Shuttle connectors, a brand-new addition to the mikroBUS™ standard in the form of a 2x8-pin IDC header with 1.27mm (50mil) pitch. mikroBUS™ Shuttle extension board is an add-on board equipped with the conventional mikroBUS™ socket, which ensures compatibility with 1147 Click boards™. Awesome graphics on MCU driven TFT Mikromedia 4 for PIC32MZ CAPACITIVE FPI with bezel is a compact development board designed as a complete solution for the rapid development of multimedia and GUI-centric applications. By featuring a 4.3" TFT display with capacitive touch screen driven by the powerful graphics controller that can display the 24-bit color palette (16.7 million colors), along with a DSP-powered embedded sound CODEC IC, represents a perfect solution for any type of multimedia application. Develop-on & build-in the same board Mikromedia 4 for PIC32MZ CAPACITIVE FPI (FPI stands for Front Panel Integration) with bezel is designed as the complete solution. It can be implemented directly into any project, with no additional hardware modifications. At its core, there is a powerful 32-bit PIC32MZ2048EFH144 microcontroller, produced by Microchip, which provides sufficient processing power for the most demanding tasks. TFT display with bezel is ideal for handheld devices, or simple installation in various kinds of industrial appliances. For most uses, a nice casing is all that is needed to turn this product into a high-performance, feature-rich device. This board requires the use of an external programmer and debugger, preferably CODEGRIP or mikroProg. The microcontroller can be programmed and debugged over the Microchip ICSP compatible 2x5 pin header, labeled as PROG/DEBUG. Specifications Type mikromedia Architecture PIC32 (32-bit) Display size 4.3" Resolution 480x272px Graphic controller SSD1963 Touch Screen Capacitive Silicon Vendor Microchip Frame Type Bezel Features USB Type C,SD Card,RF,ON/OFF switch,MP3,External DC source,Buzzer,Battery Powered,Batt. Chg. when OFF Downloads Mikromedia 4 for PIC32MZ Capacitive FPI with bezel example on libstock Mikromedia 4 for PIC32MZ Capacitive FPI with bezel manual Mikromedia 4 for PIC32MZ Capacitive FPI with bezel schematic Mikromedia 4 for PIC32MZ Capacitive FPI with bezel 2D and 3D files Powered by TCPDF (www.tcpdf.org)
MIKROE-4984
1. 物料型号:Mikromedia 4 for PIC32MZ 2. 器件简介: - 该开发板是为多媒体和GUI中心应用的快速开发设计的完整解决方案。 - 核心是Microchip生产的32位PIC32MZ2048EFH144微控制器,提供足够的处理能力。 - 配备4.3英寸电容触摸屏,分辨率为480x272像素,由SSD1963图形控制器驱动,显示24位色(1.67亿种颜色)。 - 还包含DSP驱动的嵌入式声音编解码器IC,非常适合多媒体应用。 3. 引脚分配: - 具有两个mikroBUS™ Shuttle连接器,是mikroBUS™标准的新形式,为2x8针IDC头,间距为1.27mm(50mil)。 - 还提供Microchip ICSP兼容的2x5针头,用于编程和调试。 4. 参数特性: - 架构:PIC32(32位) - 显示尺寸:4.3英寸 - 分辨率:480x272像素 - 图形控制器:SSD1963 - 触摸屏:电容式 - 硅供应商:Microchip - 框架类型:边框 - 功能:USB Type C、SD卡、RF、开/关开关、MP3、外部直流源、蜂鸣器、电池供电、关闭时电池充电。 5. 功能详解: - 该板不仅适用于多媒体应用,还扩展至其他领域,如USB、数字运动传感器、电池充电功能、SD卡读取器等。 - 包含用于快速开发的嵌入式工具,无需额外硬件修改即可直接应用于任何项目。 - 需要使用外部编程器和调试器,推荐使用CODEGRIP或mikroProg。 6. 应用信息: - 适用于手持设备或在各种工业设备中简单安装。 7. 封装信息: - 该板需要一个良好的外壳,以将其变成一个高性能、功能丰富的设备。
MIKROE-4984 价格&库存
很抱歉,暂时无法提供与“MIKROE-4984”相匹配的价格&库存,您可以联系我们找货
MIKROE-4984
  • 1+2177.245451+281.37000
