MIKROE-4976
MIKROE-4976
    MIKRO
    INA381 电流 放大器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4976 数据手册
Current 7 Click PID: MIKROE-4976 Current 7 Click is a compact add-on board providing a precise and accurate current sensing solution. This board features the INA282, a wide common-mode range, bidirectional, highaccuracy current shunt monitor from Texas Instruments. The INA282 represents a voltage output current shunt monitor that can sense drops across shunts at common-mode voltages from –14 V to +80 V, independent of the supply voltage, which operates in a range from 2.7V up to 18V supply. The zero-drift topology enables high-precision measurements with maximum input offset voltages as low as 70μV. Also, the user is allowed to process the output signal in analog or digital form. This Click board™ delivers higher performance to industrial control and automation applications, load and power supplies monitoring, telecom equipment, and many more. Current 7 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Current sensor,Measurements Applications Can be used for industrial control and automation applications, load and power supplies monitoring, telecom equipment, and many more On-board modules INA381 - current-sensing amplifier from Texas Instruments Key Features Wide input common-mode range, low power consumption, bidirectional and unidirectional current sensing, high accuracy and precision, possibility of signal processing in analog and digital form, and more Interface Analog,I2C ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V or 5V,External Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads Current 7 click example on Libstock Current 7 click 2D and 3D files MCP3221 datasheet INA282 datasheet Current 7 click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4976 价格&库存
很抱歉,暂时无法提供与“MIKROE-4976”相匹配的价格&库存,您可以联系我们找货
MIKROE-4976
    • 1+247.55774
    • 5+242.61117
    库存:18
