MIKROE-4983
MIKROE-4983
    MIKRO
    PIC32MZ2048EFH144 用于 PIC32MZ CAPACITIVE FPI 的 mikromedia 4,带框架 PIC® PIC32 MCU 32-位 评估板 - 嵌入式
MIKROE-4983 数据手册
Mikromedia 4 for PIC32MZ Capacitive FPI with frame PID: MIKROE-4983 Rich with peripherals Mikromedia 4 for PIC32MZ CAPACITIVE FPI with frame is not limited to multimedia-based applications only. USB, digital motion sensor, battery charging functionality, SD card reader and much more expands its use beyond the multimedia. Mikromedia 4 for PIC32MZ CAPACITIVE FPI with frame has two mikroBUS™ Shuttle connectors, a brand-new addition to the mikroBUS™ standard in the form of a 2x8-pin IDC header with 1.27mm (50mil) pitch. mikroBUS™ Shuttle extension board is an add-on board equipped with the conventional mikroBUS™ socket, which ensures compatibility with 1145 Click boards™. Awesome graphics on MCU driven TFT Mikromedia 4 for PIC32MZ CAPACITIVE FPI with frame is a compact development board designed as a complete solution for the rapid development of multimedia and GUI-centric applications. By featuring a 4.3" TFT display with capacitive touch screen driven by the powerful graphics controller that can display the 24-bit color palette (16.7 million colors), along with a DSP-powered embedded sound CODEC IC, represents a perfect solution for any type of multimedia application. Develop-on & build-in the same board Mikromedia 4 for PIC32MZ CAPACITIVE FPI (FPI stands for Front Panel Integration) with frame is designed as the complete solution. It can be implemented directly into any project, with no additional hardware modifications. At its core, there is a powerful 32-bit PIC32MZ2048EFH144 microcontroller, produced by Microchip, which provides sufficient processing power for the most demanding tasks. Board has a TFT display with a metal frame, and four mounting holes that enable simple installation in various kinds of industrial appliances. For most uses, a nice casing is all that is needed to turn this product into a highperformance, feature-rich device. This board requires the use of an external programmer and debugger, preferably CODEGRIP or mikroProg. The microcontroller can be programmed and debugged over the Microchip ICSP compatible 2x5 pin header, labeled as PROG/DEBUG. Specifications Type mikromedia Architecture PIC32 (32-bit) Display size 4.3" Resolution 480x272px Graphic controller SSD1963 Touch Screen Capacitive Silicon Vendor Microchip Frame Type Metal Frame Features Battery Powered,USB Type C,SD Card,RF,ON/OFF switch,MP3,External DC source,Buzzer,Batt. Chg. when OFF Display type mikromedia Downloads Mikromedia 4 for PIC32MZ Capacitive FPI with frame manual Mikromedia 4 for PIC32MZ Capacitive FPI with frame schematic Mikromedia 4 for PIC32MZ Capacitive FPI with frame 2D and 3D files Mikromedia 4 for PIC32MZ Capacitive FPI with frame example on libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4983 价格&库存
很抱歉,暂时无法提供与“MIKROE-4983”相匹配的价格&库存,您可以联系我们找货
