MIKROE-5042
MIKROE-5042
    MIKRO
    TB67S209FTG 电机控制器/驱动器,步进 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-5042 数据手册
Multi Stepper Click - TB67S209 PID: MIKROE-5042 Multi Stepper Click is a compact add-on board that contains a bipolar stepper motor driver. This board features the TB67S209FTG, CLOCK-in controlled bipolar stepping motor driver from Toshiba Semiconductor. It supports a PWM constant-current control drive, selectable mixed decay mode, and allows from full-step up to 1/32 steps resolution for less motor noise and smoother control. It has a wide operating voltage range of 10V to 47V with an output current capacity of 3A maximum in addition to several built-in error detection circuits. This Click board™ makes the perfect solution for stepping motors in various applications such as office automation, commercial, and industrial equipment. Multi Stepper Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Stepper Applications Can be used for stepping motors in various applications such as office automation, commercial, and industrial equipment On-board modules TB67S209FTG - CLOCK-in controlled bipolar stepping motor driver from Toshiba Semiconductor Key Features Low power consumption, capable of controlling 1 bipolar stepping motor, from full-step up to 1/32 steps resolution, built-in clock decoder, selectable mixed decay mode, integrated error detection circuits, and more Interface GPIO,I2C ClickID No Compatibility mikroBUS™ Click board size L (57.15 x 25.4 mm) Input Voltage 3.3V or 5V,External Driving Signal Clock Voltage Max 50V Current Max 4A Micro Step 32 RDSOn 0.49 ADMD No MO Yes Error Signal (LO) Yes ULVO Yes Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads Multi Stepper Click - TB67S209 schematic TB67S209FTG datasheet PCA9555A datasheet Multi Stepper Click - TB67S209 2D and 3D files Multi Stepper Click - TB67S209 example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-5042 价格&库存
很抱歉,暂时无法提供与“MIKROE-5042”相匹配的价格&库存,您可以联系我们找货
MIKROE-5042
库存:1
MIKROE-5042
  • 1+247.55774
  • 5+242.61117
库存:1
