MIKROE-5043
MIKROE-5043
    MIKRO
    TB67S102AFNG 电机控制器/驱动器,步进 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-5043 数据手册
Multi Stepper Click - TB67S102 PID: MIKROE-5043 Multi Stepper Click is a compact add-on board that contains a bipolar stepper motor driver. This board features the TB67S102AFNG, CLOCK-in controlled bipolar stepping motor driver from Toshiba Semiconductor. It supports a PWM constant-current control drive and allows full-, half-, and quarter-step operation for less motor noise and smoother control. It has a wide operating voltage range of 10V to 47V with an output current capacity of 3A maximum in addition to several built-in error detection circuits. This Click board™ makes the perfect solution for stepping motors in various applications such as office automation, commercial, and industrial equipment. Multi Stepper Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Stepper Applications Can be used for stepping motors in various applications such as office automation, commercial, and industrial equipment On-board modules TB67S102AFNG - CLOCK-in controlled bipolar stepping motor driver from Toshiba Semiconductor Key Features Low power consumption, capable of controlling 1 bipolar stepping motor, full-, half-, and quarter-step resolution, built-in clock decoder, integrated error detection circuits, and more Interface GPIO,I2C ClickID No Compatibility mikroBUS™ Click board size L (57.15 x 25.4 mm) Input Voltage 3.3V or 5V,External Driving Signal Clock Voltage Max 50V Current Max 4A Micro Step 4 RDSOn 0.49 ADMD Yes MO Yes Error Signal (LO) No ULVO No Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads TB67S102AFNG datasheet PCA9555A datasheet Multi Stepper Click - TB67S102 2D and 3D files Multi Stepper click - TB67S102 schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-5043 价格&库存
很抱歉,暂时无法提供与“MIKROE-5043”相匹配的价格&库存,您可以联系我们找货
