MIKROE-5067
MIKROE-5067
    MIKRO
    AS5510 磁性霍尔效应 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-5067 数据手册
Magneto 11 Click PID: MIKROE-5067 Magneto 11 Click is a compact add-on board that contains an accurate and reliable magnetic sensing device. This board features the AS5510, a linear hall sensor with 10-bit resolution, and an I2C interface from AMS-AG. It can measure the absolute position of lateral movement of a simple 2-pole magnet. A lateral stroke of 0.5mm ~ 2mm can be measured with air gaps around 1.0mm, depending on the magnet size. The AS5510 may be switched to a Power-Down state when it is not used to conserve power. This Click board™ is suitable for position sensing applications requiring a small magnetic range where noise is a critical design parameter. Magneto 11 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Magnetic Applications Can be used for position sensing applications requiring a small magnetic range where noise is a critical design parameter On-board modules AS5510 - 10-bit linear position sensor with digital position (interface) output from AMS-AG Key Features Low power consumption, highest reliability and durability, high-resolution output, operates with wide magnetic range, programmable sensitivity, and more Interface I2C ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads Magneto 11 click example on Libstock Magneto 11 click schematic AS5510 datasheet Magneto 11 click 2D and 3D files Powered by TCPDF (www.tcpdf.org)
MIKROE-5067 价格&库存
很抱歉,暂时无法提供与“MIKROE-5067”相匹配的价格&库存,您可以联系我们找货
MIKROE-5067
    • 1+104.90900
    • 5+102.80540
    库存:18
