MIKROE-5097
MIKROE-5097
    MIKRO
    DAC60508 数模转换器(DAC) 数据采集 mikroBUS™ Click™ 平台评估扩展板
MIKROE-5097 数据手册
DAC 12 Click PID: MIKROE-5097 DAC 12 Click is a compact add-on board that contains a highly accurate digital-to-analog converter. This board features the DAC60508, a general-purpose octal 12-bit analog voltageoutput DAC from Texas Instruments. It includes a 2.5V, 5ppm/°C internal reference, eliminating the need for an external precision reference in most applications, and supports the SPI serial interface, which operates at clock rates up to 40MHz. A user interface-selectable gain configuration provides full-scale output voltages of 1.25V, 2.5V, or 5 V. This Click board™ represents an excellent choice for digital gain and offset adjustment applications, programmable voltage, and current sources, programmable reference, and many more. DAC 12 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type DAC Applications Can be used for digital gain and offset adjustment applications, programmable voltage, and current sources, programmable reference, and many more On-board modules DAC60508 - octal 12-bit analog voltage-output DAC from Texas Instruments Key Features Low power consumption, high performance, integrated 2.5V internal reference, high precision, flexible output configuration, SPI compatible interface, and more Interface SPI ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads DAC 12 click example on Libstock DAC60508 datasheet DAC 12 click 2D and 3D files DAC 12 click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-5097 价格&库存
很抱歉,暂时无法提供与“MIKROE-5097”相匹配的价格&库存,您可以联系我们找货
