Analog MUX 5 Click
PID: MIKROE-5120
Analog MUX 5 Click is a compact add-on board that switches one of many inputs to one output.
This board features the MAX4634, a fast, low-voltage four-channel CMOS analog multiplexer
from Analog Devices. This low-voltage multiplexer operates from both mikroBUS™ power rails
and features 4Ω maximum ON-resistance (RON). CMOS switch construction allows the
processing of analog signals within the supply voltage range. It is also characterized by an easy
way of management, only through a couple of signals from the mikroBUS™ socket. This Click
board™ is suitable for various applications, from industrial and instrumentation to medical,
consumer, communications, and more.
Analog MUX 5 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Measurements,Port expander
Applications
Can be used for various applications, from
On-board modules
MAX4634 - low-on-resistance, low-voltage
analog multiplexer from Analog Devices
Key Features
Low power consumption, fast, CMOS switch
construction, guaranteed RON, VCC range
signal handling, TTL/CMOS-logic compatible,
pin-controllable, and more
Interface
Analog,GPIO
ClickID
No
Compatibility
mikroBUS™
Click board size
M (42.9 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
MAX4634 datasheet
Analog MUX 5 click 2D and 3D files
Analog MUX 5 click schematic
Analog MUX 5 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-5120”相匹配的价格&库存,您可以联系我们找货
