MIKROE-5125
MIKROE-5125
    MIKRO
    TMAG5170 磁性霍尔效应 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-5125 数据手册
3D Hall 10 Click PID: MIKROE-5125 3D Hall 10 Click is a compact add-on board used to detect the strength of a magnetic field in all three dimensions. This board features the TMAG5170, a high-precision linear 3D Hall effect sensor from Texas Instruments. The TMAG5170 features an SPI interface for configuration by MCU. The measurement data is provided in digital format of 12-bits corresponding to the magnetic field measured in each X, Y, and Z axes. It can achieve ultra-high precision at speeds up to 20kSPS for faster and more accurate real-time control and offers multiple diagnostics features to detect and report both system and device-level failures. This Click board™ is designed for a wide range of industrial and personal electronics applications. 3D Hall 10 Click is fully compatible with the mikroBUS™ socket and can be used on any host system supporting the mikroBUS™ standard. It comes with the mikroSDK open-source libraries, offering unparalleled flexibility for evaluation and customization. What sets this Click board™ apart is the groundbreaking ClickID feature, enabling your host system to seamlessly and automatically detect and identify this add-on board. Specifications Type Magnetic Applications Can be used for a wide range of industrial and personal electronics applications such as automation, motor-drive applications, and more On-board modules TMAG5170 - linear 3D Hall effect sensor from Texas Instruments Key Features High precision, optimizes position sensing speed and accuracy, autonomous wake-up and sleep mode, alert feature, integrated diagnostics for fault detection, integrated angle CORDIC calculation with gain and offset adjustment, low power consumption, and more Interface SPI ClickID Yes Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads 3D Hall 10 click example on Libstock 3D Hall 10 click schematic TMAG5170 datasheet 3D Hall 10 click 2D and 3D files Powered by TCPDF (www.tcpdf.org)
MIKROE-5125 价格&库存
很抱歉,暂时无法提供与“MIKROE-5125”相匹配的价格&库存,您可以联系我们找货
