ADC 18 Click
PID: MIKROE-5132
ADC 18 Click is a compact add-on board that contains a high-performance data converter.
This board features the MAX22005, an SPI-configurable twelve-channel 24-bit analog-to-digital
converter (ADC) from Analog Devices. Input channels can be used as twelve single-ended, six
differential, and up to eight multichannel configurable differential inputs. In total, the device
supports up to 26 different configurations. The ADC is used with an integrated 5ppm/°C
precision reference. Using high-voltage, zero-drift input amplifiers, standard industrial analog
input voltage ranges are converted to the ADC input voltage range. This Click board™ offers
high accuracy for the most demanding applications, from general-purpose remote data
acquisition to industrial applications.
ADC 18 Click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
ADC
Applications
Can be used for the most demanding
data acquisition to industrial applications
On-board modules
MAX22005 - twelve-channel analog-to-digital
converter from Analog Devices
Key Features
Factory-calibrated configurable industrialanalog input, high accuracy, software
configurability, 24-bit sigma-delta ADC, low
power consumption, high-speed serial
interface, high performance, and more
Interface
SPI
ClickID
No
Compatibility
mikroBUS™
Click board size
L (57.15 x 25.4 mm)
Input Voltage
3.3V,External
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
ADC 18 click example on Libstockck
ADC 18 click schematic
MAX22005 datasheet
ADC 18 click 2D and 3D files
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-5132”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+594.071221+76.95300
